Root Rooted phone verizon note 3
Dvang22
After over a year of trying i finnaly found a thread to root this phone.the reason I rooted it was because I wanted to use the hotspot. Unfortunately, it still doesn't work even with the root. It still says checking subscription status...... then it still says data not available. Any ideas? BTW I am using an unlocked Verizon phone on gosmart network.
First post.so please don't be rude lol
What is your Android version? Have you tried wifi tether router ?
The factory forces a subscription status verification.
a rooted ROM, will remove that status check and off you go just fine.
You can use Foxfi though, I used that for years on Samsung phones.
FoxFi Key (supports PdaNet) - Android Apps on Google Play
[URL='https://play.google.com/store/apps/details?id=com.foxfi']FoxFi (WiFi Tether w/o Root) - Android Apps on Google Play
[/URL]
install this first, if it works, then you will need to purchase the key that let's it run continuously.
otherwise, it will drop the signal every few minutes.
https://play.google.com/store/apps/details?id=com.foxfi.key
