Root Rooted Sammy help
KegHead
Member
Hi!
I rooted my sammy exhibit 2 4g. (t- mobile)
Is there any kind of list of apps I can safely delete?
Thanks!
KegHead
Hi!
Thanks for the info!
Also want to upgrade to ICS.
Any one out there with play by play instructions? (Ubuntu 12.04)
Thanks!
KegHead
There is no official ICS release for this phone yet. The only thing is CM9 which is a custom rom you would have to flash. The only problem is CM9 is still in beta and a lot of things aren't working properly yet with it.
