RbO1
Hi,
this thread will show you how to root doogee y300. (I also posted it on xda)
Steps:
1. Backup all your photos, apps, videos...
2. Downloads: - Sp flash tool: http://spflashtool.com/download/SP_Flash_Tool_v5.1628_Win.zip
- SuperSu: https://download.chainfire.eu/924/SuperSU/BETA-SuperSU-v2.68-20160228150503.zip?retrieve_file=1
- Twrp (recovery): https://bsp.needrom.com/2016/05/TWRP-3.0.2-1-Doogee-Y300.rar
-Drivers: http://download2151.mediafire.com/upe3ee31baeg/cypm22rgs2k83ji/MT6577+U, https://www.microsoft.com/en-us/download/details.aspx?id=19153
- Firmware (optional) (if you screw up like me): https://bsp.needrom.com/2016/07/DOOGEE-Y300-6-09.rar
3. Go to settings - about phone - spam press the build number, and soon you will see developer options enabled.
Go back to settings and click developer options, enable usb debugging and OEM unlocking.
4. Extract TWRP-3.0.2-1-Doogee-Y300.rar and you will get two files. Then extract sp flash tool.
5. Install all drivers!
6. Connect y300 to the computer. If it show up in *my computer* in files, than do this:
- Control panel - system and security - system - (on the left) device manager.
- Now you will see: portable devices - and here it will say: y300 or unknown or mtp device.
- Right click and uninstall
- Than right on computer and choose *scan for hardware changes*
- Now you will see your phone again.
- Right click and choose *update driver software* - browse my computer for driver software - Copy & Paste this path: C:\windows\inf into location.
- Now click let me pick from a list of device drivers on my computer - Choose *MTP USB Device*
- Now the computer will detect your phone.
Now you're ready to start!
1. Disconnect your phone
2. Turn it off
3. Connect your phone (wait 1 minute, vcom drivers are installing in the background)
4. Disconnect the phone
5. Run SP Flash tool
- Click *download agent* - double click *MTK_AllInOne_DA.bin*
- Click *scatter-loading* - go to where you extracted twrp, and click *MT6735M_Android_scatter-TWRP*
- Now click Download
- Now you're ready to plug in your phone. Wait 30 seconds for the process to finish.
6. Now unplug the phone and hold *Power button and volume up* - select recovery and it will boot up to twrp.
Now restart the phone and there might be a bootloop.
7. OPTIONAL (Skip if there isn't a bootloop)!!! If the phone is bricked extract the firmware. Go to sp flash tool and choose scatter loading and go to the folder of firmware and click *MT6735M_Android_scatter-TWRP*.
Click download and then connect the phone. Wait for 1-5 min for the process to complete. Now power on the phone.
- THEN REPEAT STEP 6!!
8. Connect the phone the computer and copy the SuperSu to the sd card. Unplug the phone
9. FINAL STEP! Go to recovery mode and click install - select storage - micro sd - BETA-SuperSU-v2.8-20160228150503.zip.
10. There might be an error, but no problem.
11. Now reboot the phone and install root checker. Run it and click verify root. Now you will have to give perimssion, do that and now it should say that your device is rooted.
(Sry for my english...)
OPTIONAL - IF NOTHING WORKS AND YOU KEEP GETTING ERRORS IN TWRP LIKE * cannot write /data or something* you might want to format your system as FAT. But if you do then first repeat step 7, and then 6, and then 8.
Hope you didn't brick you're and it works for you! But if you did you still have a backup right? Do you? .... I told you to make a backup... This is completely your fault
Steps:
2. Turn it off
