Root rooting help!
so in "software information" i can see software number 1.32.xxx.x
does this mean that now i can go ahead and flash a rom that i want onto my dhd?
i was going to use these steps so load the revoHD rom
How To Root, S-Off And Install Custom ROMs On The Desire HD | Hemorrdroids.net
if someone could give me the all clear that would be great!
I believe you need to downgrade and then root before you can flash to the new ROM. I tried this on mine and it lagged my HD big time. I only wanted to do this so I can remove the stock apps. I'm not 100% sure on this I just got my HD hopefully someone will reply soon.
im already on 1.32 ... anything higher than that (1.73.xxx.xx ...) thats when u need to downgrade, or so ive read!
Oh yes I think your right I have 1.84 and don't feel like going through the hassle of downgrading.. I'm dealing with the bs stock apps :S
