johnson003006
can anybody helppp i want to root my micromax ninja 4 a87
First enable usb debugging under settings -application settings-development- and insert usb cable with u r mobile , micromax driver automatically run via auto play option, just run the program and install drivers , now see device manager u r mobile driver installed .
This is about your computer autoplay option newly insert any device it shows found new hardware and it have driver itself it runs via autoplay
It is for a85. Is this also works for 87? Did you try this?
