try a different pc
DO.11
Err:A5,70,70,00,00
MEM_MAP Blank
Service Req'd
Battery Ok
Ok to Program
Transfer Mode:
USB
what is the sbf file name
how did you install drivers
pull battery, put back in
connect to charger
does charging screen load
if not, its still not correct
edit: if it charges, let it fully charge, before trying to reboot again
check charging screen, with battery
wall charger, not pc
a hour or so?
doesn't need to be full charged I guess
are you getting a charging screen?
if so if you get 40%, you could try to reboot
if reboot fails, charge phone 100%
and reflash with battery and ezSBF
good
my guess, phone didn't like your bypass
I suggest your friend, buy aBattery Desktop Charger for Motorola Droid 2
not as fast but safer
