Airmaxx23
Android Expert
I am no n00b to hacking/jailbreaking/tweaking. Rooting yes but I understand the instructions but I must be missing something. I have dropped the signed.zip on the SD root also I can not use the rev.exe to install clockwork due to no wi-fiso I downloaded it as zip renamed it to the 36img.zip (forgot the full name) (if you know what it needs to be naked for EVO 4G pls post it) dropped that tosd root also I power down with fastboot off (its not power fastboot off:::it is HOMESCREEN/MENU/SETTINGS/APPS/FASTBOOT UNCHECK) hold volume down press power let go then let go volume . Then you are in recovery mode. It should say revolutionary at the top then it scans. At this point I am lost. When it scans it finds nothing I go to recovery and select it it goes to the screen saying its loading a Rom (phone with green arrrow circled) after 5 arcs it goes to phone image with red ! In a triangle . I have to pull battery and I can't seem to figure this out pls help anyone . Also when I do use revs exe version when it asks to install clockwork I choose yes and the exe will forceclose ..
I moved this into the EVO 4G section for you, I think you'll get more help there.
http://androidforums.com/evo-4g-all...ng-issues-rev-2-3-3-help-evo-4g-new-post.html
