Voodoo OTA Rootkeeper will only work if your superuser app is up to date and you have the most up to date binaries.I Voodoo'd but it didn't do anything. After OTA ran Voodoo and tried to restore root and it did nothing.
Unfortunately, now that you're on JB, you have no way to regain root without going back to ICS. Then you'd need to root, go to the play store and make sure superuser is up to date, go to superuser and make sure your binaries are up to date, and THEN protect root with voodoo. Then it will 100% work.
Weird. that should have worked. Can you open SU and see if the binaries update? What does root checker say?I was most up to date on SuperUser and Binaries.When I click "Restore root" a popup shows "root su restored" but nothing else happens nor do any root app work.
The only thing I can think of that might cause it to not work as-above is if you voodoo protected an older version (i.e. the one that you had before you updated to the latest binaries) and didn't redo it after the update."su binary not found" and the "outdated binary notification" is checked.
This tool is all you need. It will take a little bit of time and also require a wipe of all data, but if you want root on jelly bean, it's your only way for now.
http://forum.xda-developers.com/showthread.php?t=1970267
+1Maybe someone will be able to come up with a JB root soon for this phone without going back to ICS.
