Root Rooting Problem > Wildfire S
M
MasL
Guest
Hey,
I've been through heaps of tutorials and I'm having problems. Here is what I'm doing.
1. Head over to HTCDev and select "All other supported modules"
(Reason I do this is because when I go into H-Boot it comes up with Locked)
2. From here I accept all the terms and conditions then put the phone into fastboot and then attach it to my pc via USB Cable.
3. I then download the fastboot binary for Windows (My OS).
Now on here this is where I get confused becuase I type in the code "fastboot oem get_identifier_token" on CMD it says this here. Please help me I'm not sure what's going on.
Kind Regards,
Mas
You installed a program on your computer named fastboot. You'll have to find where it is, and run that command from the folder the program is in.
