Snow_Fox
Android Expert
If I go ahead and root my nexus but, do not install custom roms, just remove default apps that are other wise unable to be removed..
Assuming my nexus one works after being rooted in such manner.. if something unforseen happens later on and it just stops working.. Would this still have voided the warranty? I understand that if i try to install a custom rom and brick the phone its my fault.. However, If I just use root the same way I would on linux I fail to see why this would void the warranty..
Is my logic somehow flawed?
