Root Rooting quetions
fessrick
I will be getting the new RAZR in a few days. I'm think of maybe rooting it & I not a phone tech so dont know much about it.
My questions are:
1 What are the advantages of rooting?
2 If Rooted can you still get the updates from Verizon?
3 Will this void the warrenty?
4 If I decide to root is there an easy step guide to follow?
5 Is there any way to get free wifi hotspot other that rooting?
Thanks
My questions are:
Thanks
Hi There :D
1. Custom roms/themes/apps/freeze bloatware
2. Usually yes, or leaked version will be available
3. Yes. There is a full recovery process available now though :D
4. Yes http://androidforums.com/razr-all-things-root/446835-motorola-droid-razr-all-things-root-guide-updated-11-24-2011-a.html
5. No.
5. When searching for a wireless tether app I saw several apps for unrooted phones. Would these not work?
Unfortunately, the owner of the site says that discussing ways to tether is considered "theft of service" unless the tethering plan is purchased from the carrier. Sorry :(
