Tattooedgod
I had some trouble Finding the info and the software I needed so I'm going to help with the new to this world. I'm going to be tinkering around to see what I can come up with. Will be including Thanks to all contributed. Will be updating as more becomes available.
Disclaimer: Neither myself or the developers are responsible for any damage you do to your phone. If you are not familiar with these methods, I'd suggest that you do some research elsewhere to better understand before you attempt anything on your device. WE HAVE NO RECOVERY AS OF YET.
Rooting:
First your gonna need the Drivers:
Win x86 --> Link
Win x64 --> Link
Install one of those first.
Second your going to need rooting program:
Bin4ary's script : http://forum.xda-developers.com/showthread.php?p=31545627 Original thread
v18 --> Link
v2 --> Link ( Which is the only one that worked for me )
Make sure you unzip[I used 7zip] into it's own folder[Makes it easier to identify]
Go to Settings, System, Developer Options and make sure USB Debugging is checked.
Connect phone to computer, and select Media Transfer on the phone
Now double click RunMe.bat file in the new folder you created.
In the newer versions[v15, v16] you will hit 1 and follow the on screen prompts, The phone will ask you to enter an encryption password... don't, just hit Restore My Data on the bottom right of the screen on your phone. Follows the rest if any prompts, the phone will reboot. Should have ROOT!!!
In older version[v2] you will hit 3 and follow the on screen prompts,The phone will ask you to enter an encryption password... don't, just hit Restore My Data on the bottom right of the screen on your phone. Follow any on screen prompts if any , the phone will reboot. You should have ROOT!!!
Confirmed Removable Apps: Always Backup First with App Backup[Titanium Backup]{remember that its always safer to FREEZE app than to delete} Original Thread
Google Movies
Music
Plus
Talk
Books
Ecomode [Only suggestion is kill the process "com.Kyocera.ecomode" before uninstalling the app or u get a recurring error popup until u reboot]
Boost Zone
Mobile ID
Stock Browser
Launcher[I removed. Remember to get a replacement FIRST]
Link2sd does work with this phone. Confirmed working with a FAT32 partition. Stable for me.
Recovery: N/A
ROMs: N/A
Bin4ry for Root
animejoe69 for helping me Root
chevanlol360 for helping to get Recovery(N/A)
stingrays for Risking Phone app removal
Robertech for Risking Phone app removal
and THANKS to anyone I might have missed.
If this has helped in anyway please hit THANKS
Rooting:
Win x86 --> Link
Win x64 --> Link
v18 --> Link
Google Movies
Music
Plus
Talk
Books
Boost Zone
Mobile ID
Stock Browser
Recovery: N/A
ROMs: N/A
Bin4ry for Root
