kemonine96
Member
This guide outlines how to gain root on the Samsung Galaxy Rugby Pro (SGH-I547 ATT / commanche). Please read through the full guide before attempting to root your device.
You will need ODIN v3.04 in order to gain root on the Rugby Pro (comanche), I will not post a link due to the nature of the package. Google has plenty of links for it.
BIG thanks to utkanos for all the help and making this a reality
Install instructions
I am not responsible for anything bad that comes to your device when using the information posted in this thread. Everything here is dangerous, may cause a brick, will void a warranty and has the potential to just plain wreak havoc. Do not complain you followed my instructions and met with a dead device. Consider yourself warned
I've tested to the best of my ability, but I am one person with one device, I cannot catch all potential failure modes. If you find a problem and a fix, or have information that should be added let me know and I will update the necessary information.
Download Links
Drivers: ATT_i547_Rugby_Pro_USB_Driver_for_Mobile_Phones_v1_4_7_0.exe
CWM 6.0.1.9 Recovery Image (KemoNine): comanche_CWR_6019_KemoNine.img KemoNine sources
CWM 6.0.1.5 Recovery Image (utkanos): comanche_cwr_6015_utkanos.tar.md5 Utkanos sources
Stock Recovery Image (UCLI3): comanche_ucli3_stock_recovery.tar.md5
CWR Root Update Zip: cwmr_root.zip
Recovery sources: https://github.com/utkanos/android_device_samsung_comancheatt
- Install drivers from link below
- Download necessary packages (clockwork recovery, root update) from the links below
- Copy root update to your devices sdcard(s) -- Copy to both if external SD card is present
- Charge phone to at least 80%
- Power off the phone
- Unplug from USB / Charger
- Boot into download mode (Home + Volume Down + Power)
- When asked if you want to continue, press Volume Up to enter download mode
- Plugin phone and
- Launch ODIN
- Check the checkbox next to "PDA"
- Click the PDA button
- Select the comanche_cwr_6015_utkanos.tar.md5 file
- Make sure only "Auto Reboot" and "F. Reset Time" are selected
- Click start
- Your phone will reboot one the flash is complete
- You now have Clockwork Recovery, continue with the steps to get root
- Power off your phone
- Boot into Clockwork Recovery (Home + Volume Up + Power -- Release when Samsung logo appears)
- Select "Install zip from sd card"
- Select "Choose zip from sd card"
- Navigate to zip
- Select zip
- Confirm
- Reboot
- You should now have root
Download Links
