rooting tonight, is one click method good to use, and best ics rom without issues
I am rooting my nexus s 4g tonight as I have caved and got tired of all of googles unanswered issues with ics... Wanting to make sure the one click root method works good and is ok to use and will it fully root to where I can flash a custom rom with odin? also wondering which ics rom is the best one out right now that doesn't have any issues such as lag, wifi, radio, calls, mms and sms
I have been running 4.0.4 the leak rom for over 2 months not even 1 glitch.
Nexus S 4g CDMA Firmware IMM26 Ice Cream Sandwich 4.0.4
the nexus s4g one click root works flawlessly. theres a vid on you tube that walks you through it. dont quote me but i believe its by qb king. yes you can flash custom roms with it. if google ever releases the ics update theres also a one click unroot that works flawlessly for the nexus s 4g
I wouldnt recommend one click root. I have a way of rooting without even the need to wipe your data just as ocr would
pm for more info
CooLoser please share what you have in open forum that is how we all learn and that is also the point of forums. I'm looking to ROOT my NXS4G as well. Also what is the problem with oneclick so I can tell others to avoid it. Thanks
nothings wrong with one click thousands of people used it it just wipes your data. there is no easier method than one click root for the nexus s 4g.
Thanks for the input timmyh but I really wanted to see what Cooloser had to say. And why oneclick was not very good........
