Root Rotate fix in tests help
dadcup
Android Expert
Hi guys I been have problem with acceleration meter I found a app the I still testing if someone want to test with me please it will be good I testing in stock now if someone have this problem in cm10 and have the cm10 install please test for me thanks I will test this in cm10 after test stock for a day or so here is the app link https://play.google.com/store/apps/details?id=com.Test_Sensors to use this install and look for all sensor in the phone or to see the sensor then select the acceleration meter sensor then hit menu bottom the select calibrate then test I will see if keep working for day or two in stock then I will test in cm10
Installed and then rebooted, now my gplay service is crashing. Running cm10.
OK. Back to CM10 deodex, but strange thing. I used a second SD card to flash ROM and Gapps, everything was good. Then put first SD card back in and lost some gplay services. Also lost the blue tint to my 4g and WiFi. Swapped SD cards again but no change. Reflashed ROM from second SD card and am worried that sensor app may have done something to the SD card. It has some strange permissions.
Ok guys the only way I found to made this work was with no app just with fresh stock and root so that mean with no deodex so I been testing for a week a it been working fine now I will try the cm10 the same way
