Root RSDlite won't detect phone
Hey Guys,
I'm trying to root my phone from stock OTA 2.1 update-1. I've followed all the guides I've been able to get my hands on. The only thing stopping me is that RSDlite is not detecting my phone when it's in Bootloader. Everything on the flash screen says that it's good to go. I've installed all the drivers and the PC does detect the Motorola Flash Device. I tried using 2 different computers, one with XP SP3 and one with Vista (ran as admin), and nothing on both. I've spent hours searching the web for similar problems and solution, I've tried just about everything and I'm about to lose it. Any one else experience something like this? Any tips on something that could fix this issue?
Thanks,
Rod
Had this problem myself, but this did the trick for me...
In RSD Lite, go to:
Config > DeviceId Options > [x] First-Come-First-Serve DeviceId Mode
Hope this works :)
Good news! After endless hours of working at it I got it to work. All I had to do was... install linux and learn how to use it, install VirtualBox and learn how to use it, install a fresh copy of WinXP in to the VirtualBox, make my way through countless fails flashes, and then format my SDcard. It was quite the experience but my phone is currently installing the latest Droidmod... and it just finished :D This was a roller coaster ride... lots of highs and lows! I'm just happy I didn't freak over all the errors I got. Thanks to everyone for your help!
All that for Droidmod??
It's my first ROM, so I decided to go for something simple to install... and after all I've been through, I just have no energy left :P
