Apps RSS Reader
saurabh44
I am new to android development.I tried this RSS Reader app using some blog.I couldn't figure out the errorin my code.Its showing ANR error.Please help !
package com.example.simplerssreader;
import java.io.IOException;
import java.net.MalformedURLException;
import java.net.URL;
import java.util.ArrayList;
import java.util.List;
import org.xmlpull.v1.XmlPullParser;
import org.xmlpull.v1.XmlPullParserException;
import org.xmlpull.v1.XmlPullParserFactory;
import android.app.ListActivity;
import android.content.Intent;
import android.net.Uri;
import android.os.AsyncTask;
import android.os.Bundle;
import android.view.View;
import android.widget.ArrayAdapter;
import android.widget.ListView;
import android.widget.TextView;
public class SimpleRSSReaderActivity extends ListActivity
List headlines=new ArrayList();
List links=new ArrayList();
@Override
protected void onCreate(Bundle savedInstanceState)
setContentView(R.layout.simple_rssreader);
ArrayAdapter adapter = new ArrayAdapter(this, android.R.layout.simple_list_item_1, headlines);
setListAdapter(adapter);
new PostTask().execute("http://feeds.pcworld.com/pcworld/latestnews");
@Override
protected void onListItemClick(ListView l, View v, int position, long id)
Uri uri = Uri.parse((links.get(position)).toString());
Intent intent = new Intent(Intent.ACTION_VIEW, uri);
startActivity(intent);
private class PostTask extends AsyncTask<String, Integer, String>
@Override
protected void onPreExecute() {
super.onPreExecute();
@Override
protected String doInBackground(String... params)
String para=params[0];
try {
URL url = new URL(para);
XmlPullParserFactory factory = XmlPullParserFactory.newInstance();
factory.setNamespaceAware(false);
XmlPullParser xpp = factory.newPullParser();
// We will get the XML from an input stream
xpp.setInput(url.openStream(), "UTF_8");
/* We will parse the XML content looking for the "<title>" tag which appears inside the "<item>" tag.
* However, we should take in consideration that the rss feed name also is enclosed in a "<title>" tag.
* As we know, every feed begins with these lines: "<channel><title>Feed_Name</title>...."
* so we should skip the "<title>" tag which is a child of "<channel>" tag,
* and take in consideration only "<title>" tag which is a child of "<item>"
* In order to achieve this, we will make use of a boolean variable.
boolean insideItem = false;
// Returns the type of current event: START_TAG, END_TAG, etc..
int eventType = xpp.getEventType();
while (eventType != XmlPullParser.END_DOCUMENT) {
if (eventType == XmlPullParser.START_TAG) {
if (xpp.getName().equalsIgnoreCase("item")) {
insideItem = true;
} else if (xpp.getName().equalsIgnoreCase("title")) {
if (insideItem)
headlines.add(xpp.nextText()); //extract the headline
} else if (xpp.getName().equalsIgnoreCase("link")) {
if (insideItem)
links.add(xpp.nextText()); //extract the link of article
}else if(eventType==XmlPullParser.END_TAG && xpp.getName().equalsIgnoreCase("item")){
insideItem=false;
eventType = xpp.next(); //move to next element
} catch (MalformedURLException e) {
e.printStackTrace();
} catch (XmlPullParserException e) {
} catch (IOException e) {
return "DONE !";
@Override
protected void onProgressUpdate(Integer... values) {
super.onProgressUpdate(values);
@Override
protected void onPostExecute(String result) {
super.onPostExecute(result);
