Run Function in Background
Hi people,
So currently i am developing application with several functions as shown below:
Function 1: Check if Device is rooted.
Function 2: List open files
Function 3: List installed applications
Function 4: List running applications
Function 5: NetCat Dump of RAM.
As of now my NetCat Dumping function runs in the foreground, which means that whenever this function is called, a black screen is displayed on the application until the netcat dumping is finished.
This black screen is a little bit of a turn off to users, so I wanna improve my application in a way such that i can run my NetCat dumping function in the background, allowing users to use the other functions of the application while the netcat dumping is in progress.
However, i am totally new to this android development, so im not sure what i should research up or look into for this. Any suggestions on what i should google or look into would be deeply appreciated :)
