Do I have to unroot once I find this nandroid, before doing the OTA?
Here's where you can update manually, after you flash 2.3.15: How to: Manually Update DROID X to Android 2.2.1 - Droid Life: A Droid Community Blog
Instructions:
1. Download this file to the root of your SD card: update.zip (alt link)
2. Do not unzip or rename the file.
3. With the update.zip file on your SD card and not in a folder, power off your phone.
4. Boot into recovery by holding down
