Sillycat41
Have an LG phone...LML414DL... and I keep getting a message that it's running out of space. I run the Smart Cleaning app and it frees up some space but not for long. It shows that 9.64 GB storage and 0.93 GB of memory are in use... 864 MN free and 1.03 GB free respectively. When I go to Settings, Apps and chose Apps that I don't use like Docs, Meet, Music, Sheets and FM Radio and chose to "Disable" them, I get this message:
Delete data and disable app? If you disable a built-in app, other apps may misbehave. Your data will also be deleted. No or Yes
Since I don't use these app, should I disable them in spite of the warning? I don't understand. ???
