Help S III default weather widget
naviwilliams
Morning all -
1. Does anyone use the default Samsung Galaxy S III weather widget?
2. Do you have it set to update automatically?
3. If the answer to the above two questions are yes, do you notice that from time to time the refresh icon will remain spinning for quite a while? (and this is in an area where you're connected to WIFI, 4G or LTE.
Thanks in advance
Ivan
I thought it was a little laggy once and a while so I installed Simi clock it's really cool and customizable.
Morning all -
1) Yes.
2) Yes, set for every hour.
3) I've not noticed it do so on any type of data connection.
i did use it, but hated the windows theme grass & sky background on it and missed having the link to the alarm clock like i had on my incredible.. someone mentioned fancy widgets app in another post that pretty much copied the htc clock/weather widget am using it now and love it :)
