Help S Memo not supported on Note 8.0
florey
I need a widget which can take notes on the spot without opening a small widget, display which note then click edit to start writing. this also needs to be displayed as full page on the home screen, able to adjust sizes of memo and stick a few on the same homescreen. I only use this for drawing with S-pen, i dont want to keyboard-type my notes.
I think S-memo would fit the need above, but its currently incompatible with Note 8.0 (According to Google Play)
I've tried other widgets below
ColorNote, Sticky Notes HD,
All of which fall short to my needs. If you have any other recommendations, please do let me know
Thanks in advance
S Memo is actually the predecessor to the S Note. This was only found on the original Note. S Memo was replaced by S Note in later Notes.
I am assuming you already tried the S Note widgets which fell short of expectation?
I use LectureNotes which I assign pages within my notebook as a widget. When the widget is tapped, it will launch the app directly to the page which you can immediately edit and work on. Not sure if that is something you are looking for? Though it sounds like you are looking for something like Post-it notes too.
Also, LectureNotes has a lot of options that can take time to go through. But once set up to your preferences, it is a decent note taking app. But that will be dependent on the user.
The trial version can be found here:
https://play.google.com/store/apps/details?id=com.acadoid.lecturenotestrial
