Help S Note
Jore
Is there a way to zoom in and out or change the size of the text? It just looks so large when jotting notes.
If you simply open a note and start writing, you are correct - it simply puts very large writing on the page.
However, you can zoom in and out of the page using the normal two finger wipe open/close action (like you use elsewhere to zoom in and out of a view). So if you zoom in fully first (ie make the page large), then write something, you can get quite a lot on.
Also, in the writing mode, use two fingers held at a fixed distance apart and wipe up/down to scroll up and down the page.
