Ive had my Evo V for a week now and I wanna get my moneys worth. I wanna do the wire trick but i dont know what kind of wire to use. Can someone tell me what kind I should be using?
just place some electrical tape/ scotch tape to the place where you hold it so your safe...I cut wire off an old charger and stippped it. Lets hope this works!
shouldn't take that long.. what does your screen look like???Problem. I'm stuck on the waiting for device to settle command. Its been like 15 mins. Is tht a bed sign?
I used a paperclip with duck tape so I could hold it. It might take a couple of tries to do the wire trick if you're confused.
