C colossus3874 Well-Known Member Feb 21, 2013 #1 Could someone point me in the direction of a good s-on Rom to flash? Don't want to mess with turning it off at this point in time
nsciucco Android Expert Feb 21, 2013 #2 http://androidforums.com/evo-v-4g-all-things-root/638604-rom-mobsterz-unsenseable-v1-2-3d-fast-lite-great-battery-life-2-14-13-a.html
C colossus3874 Well-Known Member Feb 21, 2013 #3 It says in the installation instructions of that ROM that you must be s-off. I'm s-on and running the twrp touch recovery
nsciucco Android Expert Feb 21, 2013 #5 xploPR said: I dare you do the wire trick Click to expand... LMFAO ... you can get 4ext and use the smart flash feature or you can take the boot.img out of the rom and install it. Then flash the boot.img thru ADB on your computer
Palmetto Fellow Android Expert Feb 21, 2013 #6 xploPR said: I dare you do the wire trick Click to expand... I double-dog dare him.:smokingsomb:
