I run into that problem if I'm using one note, but not S-Note. Are you using a template or just blank?I had a Note 2 and when using the Stock S Note taking app, it would automatically drop to a new page when the first page filled.
On my Note 4 the Stock S Note taking app just makes 1 giant page 1 and I can't see everything that is written after a while.
Am I doing something wrong? Is there a setting for this to automatically add pages?
Please help, as I really like this, but am very frustrated by this.
If you select a template, you will have pages to work from. Top right corner of the page, then select template, or long press recent apps key.I'm using S Note and open either a blank page or just tap the + icon.
I wish they would put out some REAL instructions on how to use this.
My Note 2 was way easier.
Here's a great tip - you can activate handwriting recognition in any text input by using the pen and tapping the small blue circular icon that appears. That might be obvious to some, but it wasn't to me.
I'm not using it at all and would like to know how people are using it. Thanks in advance!
That video is pretty good. There's quite a few I have watched on YouTube and have found them to be very helpful.
Was my Note 4 supposed to come with replacement stylus tips? I'll have to take a closer look inside the box when I get home because I don't recall seeing any.
Does anyone know what the "little eye" that pops up in the notification bar for a couple of seconds is? By the time I swipe down to see it, it disappears. It usually shows up on the end of the notifications to on the right.
good idea...I will give it a try.Got my Note 4 a couple of weeks ago. Really like this phone. I like the ability to pin the action notes to my home page. I have two home screens that I only use for pinned notes. Really handy for notes on multiple subjects or lists. Easy to open and modify and save to s-note.
