Help s pen tip stuck
akaelber
I have not come across this issue anywhere and am hoping somebody here might have a solution. I really do not want to have to bring in for service. A few weeks ago I changed the tip on my S pen to a new tip. Stored in my N8013 and put away. Later when I pulled S pen out the tip stayed in the storage spot but the rest of pen easily came out of storage spot. I tried shaking it down as well as gently putting pen back in to try and grab it with no success. It is lodged in there pretty firmly. Any ideas???
I changed mine out about that same time. No problem here! Can you even see the tip in the storage hole? Since tapping it didn't give you the desired result, you're probably going to have to do some disassembly.
