B blackcar Well-Known Member Nov 6, 2012 #1 should I take ii back, if i attempt to draw or write it adds dots and lines all over the place. makes the pen unusable.
k3Ck Well-Known Member Nov 6, 2012 #2 blackcar said: should I take ii back, if i attempt to draw or write it adds dots and lines all over the place. makes the pen unusable. Click to expand... Sounds like you have a problem to me based on from what I've seen in videos.
ScandaLeX Wasn't Me Nov 6, 2012 #3 blackcar said: should I take ii back, if i attempt to draw or write it adds dots and lines all over the place. makes the pen unusable. Click to expand... Mine was doing that but due to me not pressing hard enough. Try pressing harder; see if you get better results.
B blackcar Well-Known Member Nov 6, 2012 #4 it just happens when i lift the pen...very strange or get close to type, once it touches we are good until i lift it
james27007 Look into my Eye Nov 6, 2012 #5 check out this post: http://androidforums.com/samsung-ga...pen-not-working-after-2-days.html#post5167107 I have not tried myself but it looks like you can adjust the sensitivity
