When trying to enter date and time date into an event, a change of one text box alters the content of the others and one has to go in circles before, eventually the correct data are set. (Samsung Tab 2 7")
I have a Galaxy S4 and my wife has a Note 2. We have not had issues like you are describing. A little more detail may help diagnose the issue. I do know that I always tap the date on the calendar and then hit the + to add an event. This gets you to the correct date. I then enter the beginning time for the event first and the ending time will default to 1 hour later. I then adjust the ending time. Don't know if this helps any.
If you set the end time first, changing the start time will likely change the end time. Changing times around midnight might change the date (not certain). So it's best to set them in the order date, start, end.
