Hi all - I've just started with a Galaxy S4 (new one week ago) and have bumped into a problem with the built-in Samsung calendar, aka S-Planner. It was working just fine... There have been a bundle of software updates, including moving from Android 4.2.2 to Android 4.3, plus updates to 16 apps. And now S-planner is a bit crippled.
Symptoms: the planner opens in month view, showing the current month. The tabs on the right hand side to switch views are not there. The menu (from the bottom left perma-button) doesn't include settings. The missing features were there the other day!
Can anyone suggest how to get the app working properly again?
[Yes, I do want to continue with S-planner and don't want to install an alternative - unless forced to do so]
Thanks in advance for any help.
Edit: the problem is on the full-size Galaxy S4. S-Planner runs correctly on the S4 mini, which still has Android 4.2.2
