Help S2 stuck at pixel horizontal lines after Jellybean update!
acy2211
I've updated my s2 from ICS to Jellybean via wifi directly from the phone. After that, a page with the green android appeared and transformed into a page of many pixel like horizontal lines ,occasionally moving. Tried to restart and remove battery, download mode and recovery mode but all didn't work! Is there anyway I can fix this prob??
Hello and welcome to Android Forums acy2211! :)
Sorry to hear about you problems with the JB update. OTA, Over The Air, updates are, I'm afraid, possibly the least reliable method of updating and are shunned by a number of carriers as any interruption to your signal, or quality of signal, can cause problems with the firmware download and integration as outlined in the Firmware update problems... what you can do!. Your best bet is to re-flash your firmware as described in the guide as this should sort out your problem.
Hope this helps.
