Help S3 battery drain issue
  • Start date Start date
A
Android Question
Guest
I used GPS+HSDPA with google maps and browsed the web for about 30 mins max. I didn't keep the screen on always even when I was using the Google maps. My battery only lasted less than 5 hours. I also listened to some music for about 1 1/2 hours. I did everything in less than 5 hours.
Screen had used 31% of battery which is on the top. Then the google maps
I am using Cyanogen mod 11 Nightly. I noticed this battery issue since few months. I did that battery spin test to see if my battery is swollen and to see if it needs a replacement. But the battery seemed to be ok
