Hi all,
I've searched for this but come up blank for this specific fault.
Phone is about a month old and on Vodaphone contract. It worked fine until JellyBean OTA update. Now on regular occasions it will start to double beep every 4-5 seconds when i receive a phone call and then continue to beep after wards and until i restart the phone.
It's not beeping through the main speaker though, only through the phone earpiece speaker so it's not majorly audible unless you have the phone to your ear.
The caller can hear it also.
It will continue to beep irrespective of any volume settings including turning sounds off completely.
It continues when the phone goes to sleep.
It appears to have an effect on normal sound functions like when you swipe the screen to unlock it and you get the watery noise, that seems to be quite muted in comparison to normal when it's doing it.
No credit cards near it, no alarms set, it's not the minute minder 'cos it's every 4-5 seconds.
Re-starting the phone stops it until another call is received then it starts again and can't be silenced without re-starting the phone.
Heeeeelllllppppppp!!!!!!
