Help s3 charging problem
cat2610
My Galaxy S 3 is having charging problems. It intermittently blinks in and out of charging when attached to most cables. I ordered a wireless charger thinking it was my usb port. The wireless kit arrived today and it does the same thing.
I have found 1 charger that works...my Kindle charger/cable are the only one that works.
Troubleshooting that I've tried:
contact cleaner
canned air to clean everything out.
I've got a brand new morphine juice pack and a wireless charger I'd like to use. Any suggestions?
I had that problem sfter spilling some coke on the bottom of my s3 , when I plugged it in it flashed charging then not , I took battery out and my wife has pure alcohol being a carer so I cleaned in the charging port with that , even dripped some in and worked the lead in the port ( obviously unplugged from the mains ) and that cured it , hope it helps , btw I used all types of cleaner and only the alcohol works which can be found at a chemist
Thanks for the thoughts. I think the contact cleaner is an equivalent to the alcohol. Still none of this accounts for why my wireless charger won't work.
Any other thoughts out there?
