CarpCatcher
I want to upgrade my S3 i9300 Battery and possibly also a wireless charger.
First point are these higher power cells really that good or is it just a sicker?
for example.
3800mAh High Capacity Battery for Samsung Galaxy S3 i9300 | eBay
Also i noticed you can get a 4500mah battery but uses a larger back cover, anyone know a case that will fit after this is done?
New 4500mAh Extended Replacement Battery+Cover Case for Samsung GALAXY S3 I9300 | eBay
Lastly with the wireless charger kits, are they safe? do they cause any issues?
for example.
