Hello,
My S3 keeps volume/ringtone keeps increasing on its own. When left on a table by itself, or in my hand when I'm on my phone, it will adjust the volume/ringtone all the way to max, and then keep trying to reach max volume. When it does this, it will keep beeping, like it normally does when you change volume. But it will keep trying to increase volume.
When I disable the sound, IE put it on mute, it will automically turn the volume up all the way. Weird right?
I have tried a battery reset. I have also tried to see if the volume button was stuck, but that wasn't the case. Could it be a hardware/software issue? I don't want to download any apps, and I dont' want to do a hard reset. I tried searching the internet, but there doesn't seem to be any solid answers for this fix. Any advice and/or recommendations other than downloading an app or doing a hard reset will be much appreciated!
