Well, I know I'm getting the S3. The question is would I be better of with metro or tmobile.? Pros and cons. Thanks for the help.
Ask the community that knows![]()
Metro. You don't get throttle after a certain amount of gb useage unlike T-mobile
Now my question is... would metro's version be comparable with T-Mobile's version . I believe well get the dual 1.5ghz snapdragon if I'm not mistaken ...
There's been no leaks and definetly no announcment, tmobile s3 it is
isnt the s3 QUAD core 1.4 ghz? also id say the tmobile version would be better because the tmobile network speeds are light speeds ahead of mpcs. also i suspect mpcs version may be tuned down specs.....otherwise why not launch now?
Who's 4g is faster? Price is about the same. Both have good service I'm in south Florida. Its down to the 4g?
If you have a 42 hspa device then almost always tmobile
Sorry. What's a 42 hspa device?
after you hit your LTE quota you get throttled back to unlimited 3G
not mine I get 900kbps - 1.4mbps on 3G.if you get the $70 plan there's no throttling on metro. the most you can get with tmobile is 5GB.
metro's "3g" is garbage.
Where do you live? Here in Los Angeles my speeds are slow on my Samsung Admire.not mine I get 900kbps - 1.4mbps on 3G.
