E Evo9fq360 Lurker Dec 1, 2013 #1 I orderd s3 mini but it has some pattern on the left top corner and it says It comes with a special customised front screen. Is there any way to rub it off
Rukbat Extreme Android User Dec 1, 2013 #2 Are you sure that's not the plastic protector you're supposed to remove (by pulling the tab on the top left corner) before you use the phone?
