Help S3 mp3 audio support
Scillz
Hi all, Upgraded to the S3 today after my S2 was stolen by a Bangkok taxi driver last week lol. Anyway, I am liking it apart from one issue that has me dumbfounded and I can't seem to find any info on it from my web and forum searches.
Anyway, I only have 3 mp3 audio files that i purchased from amazon and I copied them via bluetooth from my pc to the S3 (as I did for the S2). They worked fine on the S2 but my S3 is saying the file format is not supported. Are they serious or I am doing something wrong.
Thanks in advance.
Scillz.
I think you should try copying them again. The files may be corrupted while transferring. I play MP3s just fine on my S3.
Thanks. You're right. They do work. I copied them from an old backup of my old s2 but when I copied them from Amazon they work fine. Weird. Thanks very much for your suggestion.
