s3 red charging led problem ???
edgie70
Hi all , quick question but when I put my s3 on charge in a lit up room the red led is quite bright when its on charge , but at night when I put it on charge the red led goes dimmer because its in a dark room , anybody had this problem ???? So basically charging led is bright when on charge during the day or in a well lit up room but goes dim when in the dark , weird , must say tho the led was always bright when on charge no matter whether day or night until recently , cheers , Dave :rolleyes::rolleyes:
I haven't really paid that much attention to mine.
If you want to change the color of your LED i suggest the Liteflow App. You can personalize the LED light for various things and choose different colors
https://play.google.com/store/apps/details?id=com.rageconsulting.android.lightflowlite&hl=en
I never noticed but its probably using the ambient light sensor and lowering the LED voltage to save power. Pretty smart really. Definately not a fault :)
Not sure why it's a problem? Far as I know it's supposed to do that, mine always has anyway.
it is a normal function of the ambient light sensor as mentioned above. shine a flashlight on the phone in a dark room and the LED will become brighter.
