Help s3 sms tone doesn't work
bnaser64
Hi
I am be able to send and receive sms but with out tones (no sound)
I copied one the mp3 files to this location "Computer\GT-I9300\Phone\media\audio\notifications" I did all the necessary setup but with any success
Thank you for your help
Naser
In the Messaging app, click menu, settings, scroll down to bottom of menu. Click on Select ringtone. What options do you have?
I have:
Complete action using:
Android System
ES File Explorer (which I installed from Market)
I then choose ES File Explorer, and browse to the location where I saved the .mp3 file - media/audio/notifications - I realized once I used ES File Explorer, that I didn't need to place the .mp3 in that particular folder - I think you can browse to any location on the phone and it will use the ringtone.
If you only have the Android System option, download a file manager such as ES File Explorer, because when I chose the Android System option, the file I copied to the /media/audio/notifications folder was not in the ringtone list.
Hope this helps.
I am a proud owner of a Samsung Galaxy Y and it stopped beeping when new text messages arrive.
I've tried every setting and even tried a reset factory settings. Nothing helped.
So I wrote an app to do this. Mind you, I did it mostly to solve my own problem.
It's free, there's no GUI and no ads.
If anyone is interested I uploaded it to Google Play at https://play.google.com/store/apps/d...falk.falconsms
Roy Falk
