Help..My wife accidentally downloaded 4.3, but DIDNOT install it.. Can I remove the downloaded file, so as to eliminate those annoying"install now" reminders?
I'm with you, I installed the 4.3 update 2 or 3 weeks ago and the worse thing I have experienced is the occasional wi-fi cutting out. But if I turn wifi off and then back pon it works fine for days.
Verizon Galaxy S3
Mine is rooted also after the OTA update I used saferoot and it worked just great. I am getting 6200+ as a benchmark with Quadrant, that 300 points better than I had running 4.1.2.
I'd have tro look to find the saferoot D/L but i think I got it from XDA developers.
