Whats the difference between. Bluetooth on the galaxy s3 and my f7. My bluetooth green throtle atlas controller works on a s3 but wont work on my f7 why is that?
Tryied the controller on my wifes f7. My old zte warp and my wifes htc evo 4g. Didnt work tested it on a s3 and it works great. I also cant get my remote to work on the f7 but it works on my zte warp. What would make the atlas not compatible with the f7. I know bluetooth gamepads work on the f7 bwcause ive seen videos of the ipega controller on a f7
There has to be a way to trick it. I have 2 of these controllers. I went with this one because the colors match my case and I also baught a goose neck clamp I didn't go with the controllers that had built in holders because I want my phone at eye level so I don't have to look down at my phone wile playing. My case also has a stand Another odd thing is my Wii remote won't connect ether even tho it connects to my old crappy zte warp. The atlas feels like my 360 controller that I use on my PC but I doupt that would work with out otg support.
Does the ipega have a app. I just downloaded a random joystick app when I search for the controller it came up as unknown. Then showed me a list I clicked on moga. With no results so I clicked ipega and the lights stopped blinking besides 1 which is what is supposed to happen but never has in till now. I also was able to see that button presses were working. Apparently it only works in app because I switched over to a emulator to map buttons but it wouldn't recognize keypresses and after a minute the lights started blinking so now I have to figure out how to trick the phone into thinking the atlas is a ipega
