Help S4 Active won't go in sleep mode when charging
jaydub110
Need help. I just got my S4 Active today & when it's charging the phone it won't go into sleep mode the light fades down but doesn't completely turn off unless I hit the power button. Is there something in settings that I can turn off for it to work ? I can't figure out :confused: I have a docking station on my night stand & I want it to shut down completely to sleep.
That's pretty normal, I think. Works that way on my Galaxy Note, at least. Might be a setting that tells phone to leave screen on when plugged in, though.
Go to settings, more, developer options, and uncheck the stay awake option. I had the same problem and just now found the solution.
Thanks that did the trick. Just couldn't figure it out I keep my phone on my nightstand on my docking station & the light was beginning to annoy me.:)
