girolez Often Off Piste Nov 16, 2014 #2 Hi Have you enabled gps? Pull down the notification bar and click on the icon, or menu button system settings location services tick "Use gps satellites" Are you in a building? GPS satellite signals do not penetrate buildings very well - try it outside. Is it just google maps? Install GPS Test from the play store and see what that tells you. Hope this helps Roger
