S4 S Voice
danielunde
I installed S 4 S Voice on my S 3 and it was working fine and now it says network error so i uninstalled it back to factory S Voice and now it works fine. Anyone know whats going on with this? Thanks!
Mine is doing the same thing! It will work when I tell it to do commands like set an alarm, but as soon as I say anything that it requires it to search it says An unexpected server error occured. Please try Again.
Anyone know?? I reset the app, cleared the cache and everything, but couldn't find a way to uninstall it because it seemed to be at factory default. (Unless I'm doing something wrong?)
Go to settings/ Application manager/scroll down to S Voice and uninstall the update. Once you do that it will put it back factory S Voice.
I guess mine never had an update (just got the phone not long ago) so I can't uninstall anything. It still isn't working, really annoying.
