[S4 Widgets & Mods for S3]
nuttmeg
Extreme Android User
Source: DroidViews | Install Galaxy S4 Weather Clock Widget & Music Player on Your Samsung Galaxy Phone
Originally posted by Rakesh Shukla
If you like the new weather clock widget of the upcoming Samsung Galaxy S4 and want to have it on your Galaxy S3, Note, Note 2, S2, etc., you can now have it. XDA member XdroidPerfect has come forward with his modded AccuWeather widget that will replace the original widget found in current Galaxy phones to look like that of Galaxy S4. The mod is so perfect that one cannot point out a difference
The widgets available below have been made by different modders and now they contain the original png files from Galaxy S3′s system dump. So they look more genuine now. Most of the S4 Weather widgets for S2 nd S3 have been modded by dr30ma so all due credits to him.
Note:
Most of these mods work on a deodexed stock-based custom ROMs. Make sure you have it on your phone before attempting to install. To avoid any mishap, do not forget to backup your current ROM in CWM.
For All Android Phones with Deodexed JB ROM:
Galaxy S4 Launcher and AccuWeather Widget
Galaxy S3 Only:
Make sure your phone in on latest rooted stock or a TouchWiz-based custom ROM like Omega, FoxHound, WanamLite, Neat ROM etc. If your phone has older firmware, the mods might not work on it.
For Galaxy S3 on Leaked 4.2.1
4.2.1_AccuWeather Widget S4 +Main_New.zip
25% Trans_4.2.1_AccuWeather Widget S4_New.zip
50% Trans_4.2.1_AccuWeather Widget S4_New.zip
75% Trans_4.2.1_AccuWeather Widget S4_New.zip
100% Trans_4.2.1_AccuWeather Widget S4_New.zip
For Galaxy S3 on Leaked 4.1.2
4.1.2_AccuWeather Widget S4 +Main_New.zip
25% Trans_4.1.2_AccuWeather Widget S4_New.zip
50% Trans_4.1.2_AccuWeather Widget S4_New.zip
75% Trans_4.1.2_AccuWeather Widget S4_New.zip
100% Trans_4.1.2__AccuWeather Widget S4_New.zip
1. Copy the zip file to your phone’s internal or external SD Card storage without extracting it.
2. Now boot your phone into ClockWorkMod recovery mode: press and hold Volume Up+Home+Power buttons for about 3-5 seconds.
3. Needless to say, you will have to use the volume and power keys to scroll up or down and select options.
4. Do not forget to backup your current ROM using “backup and restore” option in CWM.
5. Go to “advanced” and “wipe dalvik cache” (do it before and after installation)
6. Now scroll to “install zip from sdcard> choose zip from sdcard“, navigate to the widget file and select it.
7. It will be installed in a few seconds and when it is done, reboot the phone.
8. If your phone is on stock rooted firmware and you do not find the widget after flashing, install a root file explorer and navigate to the system/app folder. Here, you will find the following files: AccuWeatherWidget.odex and AccuWeatherWidget_Main.odex. Copy single/ both the files to the external storage of your device and then delete the original Odex files from the System/app folder. Finally, reboot the phone.
If you still have problem, clear app data from Settings> Application Manager> ALL> after flashing the zip:
Source: http://forum.xda-developers.com/showthread.php?t=2278436
Thanks to rush25 @ xda be sure to visit the thread and thank him personally and everyone else that was involve.
Galaxy S3 lockscreen
Just please have a backup
Features :-
-Flare Lock from S4 4.2.2 to S3 4.1.2
-Works on All Stock Roms [Odexed or Deodexed]
-S4 unlock sounds
Instructions :-
-Download the file
-Copy to sd card
-Reboot in recovery
-Flash the file
-Reboot
Credits :-
-Koulis2000 [Original Thread]
-salesale
-Villain Rom Team
Downloads :-
-Build 1
Mods :-
-Mod 1
Source: Midnight Gapps Project
Links: Can be found here and thanks goes to cajunflavoredbob @ xda
http://forum.xda-developers.com/showthread.php?t=2183408
For AOSP Roms
: But alot of apps can be pull and install on cm10 base roms.
Click the image for a bigger preview. Midnight Gapps Project
  • Which zip should you choose?
  • show
  • Instructions
  • show
  • Included Apps
  • show
  • Update Log
  • show
Full Flash zip is a full and complete gapps package for your JB 4.2+ ROM. Just flash your ROM.zip and then this one. No need to flash any other gapps packages at all.
Quick Flash zip is a simple zip that installs all the inverted apps by b-boy into their proper places. This should be flashed after your normal gapps package for JB 4.2+.
Update zips are meant for going from the previous version to the newest version without needing to wipe everything. These are only available for minor updates.
I've made a zip with many of B-boy's apps included for easy installation. Please understand, that I've tried my best to make certain that all old apps are removed automatically by the zip, but it isn't possible to get all of them. So, please do yourself a favor and install this on a clean flash so it works properly.
The installation instructions are simple: pick the zip you want, flash it in recovery, then reboot. Do not restore data from your old non-inverted apps. Odexed ROMs are not supported. If you run into any problems, wipe everything and try it from a clean install to make sure it isn't one of your apps playing tricks on you.
Inverted Stock Apps -
  • Calculator 3.1.2
  • Calendar 4.2.2
  • Email 4.1
  • Messaging 4.2.2
  • People 4.2.2
Inverted Google Apps -
  • Gmail 4.3.1
  • GmsCore (Google Settings) 3.1.36 (669520-36)
  • Google Currents 2.0.1
  • Google Drive 1.1.592.10
  • Google Hangouts 1.0.1.678536
  • Google Keep 1.0.79
  • Google Maps 6.14.3
  • Google Now 2.4.10.626027
  • Google Play Music 5.0.1026J676641
  • Google Play Store 4.1.6
  • Google Plus 3.6.0.44338848
  • Google Translate 2.7
  • Google Voice 0.4.2.80
  • YouTube 4.4.11 v5b w/1080p HD mod
Other Inverted Apps -
  • Apollo Music 1.1
  • Amazon 2.4.0
  • Box 2.1.5
  • Chrome 26.0.1410.58
  • Copy 2.00.049
  • Craigslist 1.49
  • Dropbox 2.3.7
  • eBay 2.1.3.1
  • ES File Explorer 3.0.3
  • Facebook 3.2
  • FB Messenger 2.4.3
  • Flipboard 2.0.1
  • Instagram 3.5.3
  • Kik Messenger 6.2.0.26
  • LinkedIn 3.0.0
  • Mighty Text (Tablet) 1.75
  • Pandora 4.2
  • Pinterest 1.4.3
  • Skype 3.2.0.6673
  • Spotify 0.5.9.29
  • Twitter 4.0.2
  • WhatsApp+ 2.9.5297
  • WordPress 2.3.1
  • Yahoo Mail 2.0.7
The following things changed since the previous version 1.7.4
  • Pretty much everything
  • Full Wipe REQUIRED!!!!
Gmail 4.5
Click To Download
They all will work on asop roms and all the links is for different transparent % that you want, like i have 100% transparent.
Updated post 2 with some nice inverted apps and stuff. The creator didn't want his link posted no where so i posted the thread for everyone to see and check it out, and be sure to thank him. :)
OP updated with lock screen, but im not getting the same lock screen from the post above, but make sure you disable the ripple affect.
