Help S5 issue with connecting to PC
Arthur14
I'm trying to transfer files from my phone to pc but nothing is happening when connecting the phone to PC. The mobile drive comes up & then disappears. I loaded smart switch (old ver=Samsung Kies3) and the Verizon app but still nothing.
When I 1st got my phone I connected & was able to transfer with no issues.
Can someone help?
May be a driver problem. If you are running Windows check out Device Manager to see if the connection is there as well as any error messages. I would have expected Smart Switch to have installed the drivers so maybe the cable is faulty. BTW make sure you use the one supplied.
Cable seems to work fine, my computer seems to sense it since when I attach the cable, Smart Switch starts trying to connect each time. After trying to connect, I get a connection failed comment. Then I unplug & replug the cable & it starts over again.
What do you mean "use the one supplied"? I had a Verizon wireless shared utility load up & I thought this would work but still nothing.
