Trying to sync POP3 email to a Samsung S5 from Sprint.
Outlook 2010 on desktop works fine accesing the email via POP3. Old phone had no problems syncing email as well.
Sync works for an hour or maybe a day, then stops. Refresh doesn't work (and it doesn't seem to be even trying to sync). Sync is on. Autosync Data is on. Airplane mode is off. Rebooting makes no difference. Took it to the Sprint store and they were no help except to verify that the email settings appear correct.
The only way I've found to get it to sync again is to delete the email account and add it again, but alas it just stops syncing again after a while.
Thanks for any ideas or help. (I'm going to install K-9 to see if I can work around this.)
