Help S5 sd photo transfer
I transfered my photos from my device to my sd card by going into the file and choosing select all instead of choosing the folder and now my photos are all unorganized. Is there any way to get them re organized again??
I did that, and it didnt change. I used to have quickpic for my older phone but I need to know if theres anyway to restore the dates because once I went into My Files and moved all my photos to my sd card the original date of the photo changed to the date that the photo was moved
I understand. No ı don't think you can...maybe only if you had any cloud back-up you could restore...
That will happen under just about any OS, the copied file creates a "creation date".
sorry, but you are just going to have to live with it, or manually change the dates... a PITA
